Is anyone using IE 8 together with a version 3 of Umbraco?
Our company is planning to upgrade the employee PC's to IE8 and are asking the application managers to check wether it is compliant/working?
Additionally, how is Umbraco 4 doing on IE8?
Is this working too?
I haven't encountered any problems with the backend of umbraco. I did have some troubles with the front-end, but I solved that by forcing IE8 to treat the site IE7-compliant.
Umbraco 3.x with IE 8?
Hi everyone,
Any answer would be much appreciated,
Thx, Len.
I found some other post mentioning to put Umbraco code into IE 7 compatibility mode too, is that necessary for the Umbraco back-end?
Here is the post: http://forum.umbraco.org/yafpostst9761modaljs-Not-implemented.aspx
Fully compatibility with IE8 & IE 9.
Getting some issue with the front-end, but I solved. IE8 or IE 9.
Rajeev
