  • Claus Jensen 49 posts 157 karma points hq
    Jun 10, 2011 @ 11:00
    Claus Jensen
    TinyMCE - Insert Picture error
    I'm having some issues with TinyMCE editor in Umbraco 4.7. When I right-click in the editor and select 'Insert Image', something seems to be missing. Instead of the texts such as "image source" I see "#advanced_dlg.image_src", and I don't see the media picker at all.
    To me it seems like some files are missing in my installation?
    The really weird thing is that if I use the 'Insert Image' button in the toolbar instead - everything works just fine?
  • Drew 165 posts 340 karma points
    Jun 10, 2011 @ 12:51
    Drew
    Looks like a bug to me, I just used the same right-click "insert image" option on a fully-working 4.7 installation and get the exact same screen as you do.
    It appears that the label placeholders aren't being replaced with the text.
    Umbraco: 4.7
    Browser: Chrome 11
  • praveity 100 posts 125 karma points
    Jun 15, 2011 @ 07:26
    praveity
    I have also found the same issue on the umbraco ui.
    Seems like its a bug.
  • Jeffrey Schoemaker 408 posts 2138 karma points MVP 8x c-trib
    Nov 17, 2011 @ 13:31
