  • devore_uk 13 posts 2 karma points
    Jun 14, 2009 @ 23:18
    devore_uk
    Previewing pages with macros on
    It seems that when I preview a page that has macros the macro's don't display any content at all. Is this a problem with the way I have written the macros or a limitation of the preview function.
    Can I only preview content that is displayed as an umbraco field?
  • Nik Wahlberg 639 posts 1237 karma points MVP
    Jun 23, 2009 @ 01:43
    Nik Wahlberg
    For each Macro that you create you will want to check-off the "Render content in editor" in orde to see the content in a RTE control.
    Cheers..
  • Casey Neehouse 1339 posts 483 karma points MVP 2x admin
    Jun 23, 2009 @ 02:01
    Casey Neehouse
    2
    Nik,
    Macros render against the published data.  If the node is not published, the Macro will not have a node to render against.  Umbraco Item tags pull the unpublished content when in preview mode.
    Case
