I would like to do insert/update or delete on the database table in the Umbraco backend. So I made a custom section and loaded the rows of table in the right content pane. I had use gridview control for this purpose. Now I want the functionality of delete, update or insert but none of the events fires. Also I could even do the simple sorting on gridview.
It seems like umbraco overrides those as I could see my buttons just refresh the page. On hover theres a javascript function being fired.
e.g. javascript:__doPostBack('ctl00$body$gbTagsTable','Sort$value')
How can do edit/ sort the asp.net gridview on Umbraco?
Did you ever get a response to this? I realise there's a bug in thedashboard.config that stops postback functionality in any controls placed on the dash, but I've removed that bit of the config and I'm still not seeing sorting work on a gridview.
Just for sake of testing, have you tried to run your grid on a asp.net page, not running inside the umbraco context, either in a different asp.net app, or make sure umbraco "ignores" your page by changing the key umbracoReservedUrls/umbracoReservedPaths in the web.config.
@Shaun: I think you're referring to the fact, that, once you add multiple dashboard controls (requiring postbacks) on the content section dashboard, events aren"t firing because there's no postback initiated, this is due to the fact that the first control (to change the user's password) has field validators which disallow posting back if not supplied. Removing that control and making sure you set validationgroup on your own custom controls fixes that.
Asp.net controls does not work in Custom Section
Hi to all,
Anyone else noticed this?
pravity,
/Dirk
