The tinyMCE plugin in Umbraco uses an Umbraco theme. Changing the styles there should filter through to the editor as the default styles. Here is the path to the file:
You can edit the Rich Text Editor data type (tinymce) CSS styles that are included when the WYSIWYG is displayed in the back end.
1) Create a new CSS file under your Settings > CSS. Call it "CMS". Set the CSS so that it overloads the default TinyMce styling. (i.e. set the style for p, span, etc, etc).
Developer menu > Data Types > Rich Text Editor
Under the tinymce settings you'll be able to choose CSS files to be implemented - just tick the CMS.css checkbox.
TinyMCE: change default styles
Hi to all,
My client wants the same font-family and font-size as there is for the website. Can we change the default styling of tinymce for this purpose?
I don't want to have a stylesheet on the dropdown in UI, it needs to be default for the RTE.
Please help me through :)
Thanks in advance.
Hi there,
Here is some more information about this (more of a starting point if there is any complication with actually changing the styles):
http://tinymce.moxiecode.com/wiki.php/Configuration:content_css
HTHs :)
