  • adamsimsy 31 posts 46 karma points
    Jun 14, 2011 @ 15:28
    adamsimsy
    Umbraco UI conformance for Authoring Tool Accessibility Guidelines (ATAG 1.0 and 2.0)
    Hi All,
    i've tried searching for information about this topic to see if anyone has checked to see which guidelines of ATAG 2.0 Umbraco meets, but as i anticipated i didn't find much.
    So i thought i would ask the question to see if anyone knows what guidelines Umbraco backoffice UI conforms to ATAG 2.0?
    If there is no information about this, then i thought this topic would be a place to start things off!
    Regards,
    Adam
  • Martijn Beumers 13 posts 172 karma points
    Jun 27, 2011 @ 20:39
    Martijn Beumers
    I don't think Umbraco v4 is ATAG-compliant.
    If you disable javascript and try to log in then the only thing you'll see is a loading screen. Hopefully Umbraco v5 will be ATAG-compliant..
    Regards,
    Martijn
