I am also a web form developer and used 4.0 webfrom routing feature. I recently started a project on umbraco so just wondering, is there possibilities to implementing webform routing as you raised question?
Thanks Nate, I will follow your suggestion and it looks great.
Someone has posted an article to work around the asp.net routing features, I didn't got a chance look into more. Soon I will you updated here if works for me.
URL Routing in Umbraco
I'm trying to setup webforms routing in umbraco.
I have a content page off the route called "ride". I'd like to change it from www.mysite.com/ride?id=12345 to www.mysite.com/ride/12345
I've added the following to a class in the app code folder.
But that gives me a 404.
I've also tried adding ~/ride/ to umbracoReservedUrls umbracoReservedPaths in the web.config
Does anyone know how to get this to work?
you could use the standard urlrewriting that is part of umbraco
Open urlrewriting from the config-folder and edit that file.
HTH,
Peter
How would I serve up that content then if I did do the URL rewriting?
With URL routing, I was going to have one macro on the ride page that would get the RideGUID like this:
Guid rideGuid = new Guid(Page.RouteData.Values["category"] as string);
If I did URL rewriting doesn't that make it so it expects a page at http://www.mysite.com/ride/BB067C2C-2627-4383-9B16-694BA62B7CF5?
Bump. Anyone have any ideas?
Hi Nate,
Please reply me.
Parwej
I did it through URL Rewrite that's provided by umbraco in the UrlRewriting.config file
<add name="CyclingRides"
virtualUrl="^~/cycling/rides/(?<RIDE_ID>[0-9]+)$"
destinationUrl="~/cycling/rides?id=${RIDE_ID}"
ignoreCase="true" rewrite="Application" />
That changes /cycling/rides?1234 to /cycling/rides/1234. I also have acecss to ID through request.querystring on my page. Works great!
http://wishfulcode.com/2010/09/19/asp-net-routing-and-virtual-article-based-extensionless-website-urls/
Parwej
I know it is an old topic, but i cant seem to find UrlRewriting.config file in my porject, i am using Umbraco 5.0.1 CMS Web Application
from codeplex site,
Thanks in Advance,
Sher
