  • Nate 143 posts 184 karma points
    Jun 20, 2011 @ 01:29
    Nate
    URL Routing in Umbraco
    I'm trying to setup webforms routing in umbraco.
    I have a content page off the route called "ride".  I'd like to change it from www.mysite.com/ride?id=12345 to www.mysite.com/ride/12345
    I've added the following to a class in the app code folder.
    public class Global : umbraco.Global
        /// <summary>
        /// Code that runs on application startup
        /// </summary>
        /// <param name="sender"></param>
        /// <param name="e"></param>
        protected override void Application_Start(object sender, EventArgs e)
            base.Application_Start(sender, e);
            RouteTable.Routes.Add("RideRoute",
                                    new Route("ride/{RideGuid}",
                                    new PageRouteHandler("~/ride")));
    But that gives me a 404.
    I've also tried adding ~/ride/ to umbracoReservedUrls umbracoReservedPaths in the web.config
    Does anyone know how to get this to work?
