  • Michiel (NSC) 95 posts 115 karma points
    Jun 22, 2011 @ 16:27
    Michiel (NSC)
    How can I work with neutral cultures in Languages?
    I wanted to add a neutral culture, so just English, not English (United Kingdom) or English (Ireland), but I found out I can add that as a language. Only specific cultures.
    When I first add English (united Kingdom) it seems that I can then change it to English: select node, in the Edit Language tab select English, click save button...
    ...result is disappointing: tab name is changed to [editLanguage], label in front of select has disappeared, node is NOT renamed even after reloading. Clicking the node again and nothing is changed :-(
    How should it work?
    Jun 22, 2011 @ 20:33
    Sebastiaan Janssen
    I'm afraid Umbraco currently has no support for a neutral English culture, what is the specific reason that you need this? Is there no way you could just use UK and be done with it? I'm not sure I understand why neutral would be better.
    Jun 23, 2011 @ 09:58
    Michiel (NSC)
    Ok, I understand. Thanks!
    I just thought neutral would be more logical and I am just discovering the feature and trying to figure out how it works :-)
    It does seem like there's a bug in the UI, so I have posted two tickets on Codeplex:
    http://umbraco.codeplex.com/workitem/30333
    http://umbraco.codeplex.com/workitem/30332
