With Umbraco it's easy to output the mark up as you need to, so what I would suggest is go and find a mega menu you like and post the markup here along with your site structure, this will give people a better chance to help you.
<xsl:output method="xml" omit-xml-declaration="yes"/> <xsl:param name="currentPage"/> <!-- Holds the start node for the navigation. Optional --> <xsl:param name="startNodeId" select="/macro/startNodeId"/> <!-- Holds number of sublevels to generate. Macro parameter is optional. Defaults to one if not supplied --> <xsl:param name="maxDrilldownLevel" select="netaddicts-be:ReadMacroParameter(//macro/maxLevels,'0')"/>
<xsl:template match="/">
<!-- Check whether a start node has been supplied --> <xsl:choose> <xsl:when test="$startNodeId != ''">
<!-- Start building the top navigation from the node supplied by start node id -->
<!-- Create var for easier reading/processing --> <xsl:variable name="currentProcessedNode" select="."/> <xsl:variable name="currentLevel" select="0"/>
<!-- Check whether node should be visible in first level navigation --> <xsl:if test="string($currentProcessedNode/umbracoNaviHide) != '1'"> <xsl:choose> <xsl:when test="position() != $NoOfChildren"> <li>
<!-- Build the navigation link using the node currently being processed in the for-each loop --> <xsl:call-template name="buildLink"> <xsl:with-param name="node" select="$currentProcessedNode"/> </xsl:call-template>
<!-- Build next level navigation only if applicable --> <!-- Still need to check whether all child nodes have been set to umbracoHideChildren = 1 whereas umbracoNaviHide = 0 this case would yield an empty ul element --> <xsl:if test="(count($currentProcessedNode/node) > 0) and (string($currentProcessedNode/umbracoNaviHide) != '1') and ($currentLevel < $maxDrilldownLevel)"> <xsl:call-template name="buildNavigation"> <xsl:with-param name="parentNode" select="$currentProcessedNode"/> <xsl:with-param name="level" select="$currentLevel + 1"/> </xsl:call-template> </xsl:if>
</li> </xsl:otherwise> </xsl:choose> </xsl:if>
</xsl:for-each>
</ul>
</xsl:template>
<!-- A template used for building the non top navigation tree --> <xsl:template name="buildNavigation"> <xsl:param name="parentNode"/> <xsl:param name="level"/>
<ul> <!-- Iterate over the child nodes--> <xsl:for-each select="$parentNode/* [@isDoc]">
<!-- Check whether node should be processed --> <xsl:if test="string($currentProcessedNode/umbracoNaviHide) != '1'">
<li>
<!-- Build the navigation link --> <xsl:call-template name="buildLink"> <xsl:with-param name="node" select="$currentProcessedNode"/> </xsl:call-template>
<!-- Build next level navigation only if applicable; recursive call --> <!-- Still need to check whether all child nodes have been set to umbracoHideChildren = 1 whereas umbracoNaviHide = 0 this case would yield an empty ul element --> <xsl:if test=" (count($currentProcessedNode/node) > 0) and (string($currentProcessedNode/umbracoHideChildren) != '1') and ($level < $maxDrilldownLevel)"> <xsl:call-template name="buildNavigation"> <xsl:with-param name="parentNode" select="$currentProcessedNode"/> <xsl:with-param name="level" select="$level + 1"/> </xsl:call-template> </xsl:if>
</li>
</xsl:if>
</xsl:for-each>
</ul>
</xsl:template>
<!-- A template that builds our navigation link based on node properties --> <xsl:template name="buildLink"> <xsl:param name="node"/>
<xsl:choose>
<!-- Build link to external page --> <xsl:when test="string($node/externalURL) != ''">
<!-- A template that builds a link to an external page --> <xsl:template name="buildExternalLink"> <xsl:param name="node"/>
<!-- <xsl:call-template name ="outputNode"> <xsl:with-param name="currentNode" select="$* [@isDoc]"/> </xsl:call-template> -->
<a Target="_blank"> <!-- Set the href attribute --> <xsl:attribute name="href"> <xsl:value-of select="$node/externalURL"/> </xsl:attribute> <!-- Set the target attribute if available from the properties --> <xsl:if test="string($node/externalTarget) != ''"> <xsl:attribute name="target"> <xsl:value-of select="$node/externalTarget"/> </xsl:attribute> </xsl:if> <!-- Set the title attribute if available from the properties --> <xsl:if test="string($node/navTooltip) != ''"> <xsl:attribute name="title"> <xsl:value-of select="string($node/navTooltip)"/> </xsl:attribute> </xsl:if> <!-- Set actual text for the link, either available from the properties or just plain umbraco link--> <xsl:choose> <xsl:when test="string($node/navText) != ''"> <xsl:value-of select="string($node/navText)"/> </xsl:when> <xsl:otherwise> <xsl:value-of select="$node/@nodeName"/> </xsl:otherwise> </xsl:choose> </a>
<a> <!-- Set the href attribute based on the redirect supplied --> <xsl:attribute name="href"> <xsl:value-of select="netaddicts-be:FixLink(string($node/umbracoRedirect))"/> </xsl:attribute> <!-- Set the title attribute if available from the properties --> <xsl:if test="string($node/navTooltip) != ''"> <xsl:attribute name="title"> <xsl:value-of select="string($node/navTooltip)"/> </xsl:attribute> </xsl:if> <!-- Set actual text for the link, either available from the properties or just plain umbraco link--> <xsl:choose> <xsl:when test="string($node/navText) != ''"> <xsl:value-of select="string($node/navText)"/> </xsl:when> <xsl:otherwise> <xsl:value-of select="$node/@nodeName"/> </xsl:otherwise> </xsl:choose> </a>
<xsl:choose> <xsl:when test="$currentPage/ancestor-or-self::node/@id = current()/@id"> <xsl:choose> <xsl:when test="(count($node/node) > 0)"> <a class="active" rel="dropmenu{position()}"> <!-- Set the href attribute, either the alias if available, else use NiceUrl() --> <xsl:attribute name="href"> <xsl:choose> <xsl:when test="string($node/umbracoUrlAlias) != ''"> <xsl:value-of select="netaddicts-be:FixLink(string($node/umbracoUrlAlias))"/> </xsl:when> <xsl:otherwise> <xsl:choose> <xsl:when test="number($node/@level) = 1"> <xsl:for-each select="$node/child::* [@isDoc]"> <xsl:if test="position()<= 1"> <xsl:variable name="currentProcessedNode" select="."/> <xsl:value-of select="umbraco.library:NiceUrl($currentProcessedNode/@id)"/> </xsl:if> </xsl:for-each> </xsl:when> <xsl:otherwise> <xsl:value-of select="umbraco.library:NiceUrl($node/@id)"/> </xsl:otherwise> </xsl:choose>
</xsl:otherwise> </xsl:choose> </xsl:attribute> <!-- Set the title attribute if available from the properties --> <xsl:if test="string($node/navTooltip) != ''"> <xsl:attribute name="title"> <xsl:value-of select="string($node/navTooltip)"/> </xsl:attribute> </xsl:if> <!-- Set actual text for the link, either available from the properties or just plain umbraco link--> <xsl:choose> <xsl:when test="string($node/navText) != ''"> <xsl:value-of select="string($node/navText)"/> </xsl:when> <xsl:otherwise> <xsl:value-of select="$node/@nodeName"/> </xsl:otherwise> </xsl:choose> </a>
<a class="active"> <!-- Set the href attribute, either the alias if available, else use NiceUrl() --> <xsl:attribute name="href"> <xsl:choose> <xsl:when test="string($node/umbracoUrlAlias) != ''"> <xsl:value-of select="netaddicts-be:FixLink(string($node/umbracoUrlAlias))"/> </xsl:when> <xsl:otherwise> <xsl:value-of select="umbraco.library:NiceUrl($node/@id)"/> </xsl:otherwise> </xsl:choose> </xsl:attribute> <!-- Set the title attribute if available from the properties --> <xsl:if test="string($node/navTooltip) != ''"> <xsl:attribute name="title"> <xsl:value-of select="string($node/navTooltip)"/> </xsl:attribute> </xsl:if> <!-- Set actual text for the link, either available from the properties or just plain umbraco link--> <xsl:choose> <xsl:when test="string($node/navText) != ''"> <xsl:value-of select="string($node/navText)"/> </xsl:when> <xsl:otherwise> <xsl:value-of select="$node/@nodeName"/> </xsl:otherwise> </xsl:choose> </a> </xsl:otherwise> </xsl:choose> </xsl:when>
<xsl:otherwise> <xsl:choose> <xsl:when test="(count($node/node) > 0)"> <a rel="dropmenu{position()}"> <!-- Set the href attribute, either the alias if available, else use NiceUrl() --> <xsl:attribute name="href"> <xsl:choose> <xsl:when test="string($node/umbracoUrlAlias) != ''"> <xsl:value-of select="netaddicts-be:FixLink(string($node/umbracoUrlAlias))"/> </xsl:when> <xsl:otherwise> <xsl:choose> <xsl:when test="number($node/@level) = 1"> <xsl:for-each select="$node/child::* [@isDoc]"> <xsl:if test="position()<= 1"> <xsl:variable name="currentProcessedNode" select="."/> <xsl:value-of select="umbraco.library:NiceUrl($currentProcessedNode/@id)"/> </xsl:if> </xsl:for-each> </xsl:when> <xsl:otherwise> <xsl:value-of select="umbraco.library:NiceUrl($node/@id)"/> </xsl:otherwise> </xsl:choose> </xsl:otherwise> </xsl:choose> </xsl:attribute> <!-- Set the title attribute if available from the properties --> <xsl:if test="string($node/navTooltip) != ''"> <xsl:attribute name="title"> <xsl:value-of select="string($node/navTooltip)"/> </xsl:attribute> </xsl:if> <!-- Set actual text for the link, either available from the properties or just plain umbraco link--> <xsl:choose> <xsl:when test="string($node/navText) != ''"> <xsl:value-of select="string($node/navText)"/> </xsl:when> <xsl:otherwise> <xsl:value-of select="$node/@nodeName"/> </xsl:otherwise> </xsl:choose> </a>
<a> <!-- Set the href attribute, either the alias if available, else use NiceUrl() --> <xsl:attribute name="href"> <xsl:choose> <xsl:when test="string($node/umbracoUrlAlias) != ''"> <xsl:value-of select="netaddicts-be:FixLink(string($node/umbracoUrlAlias))"/> </xsl:when> <xsl:otherwise> <xsl:value-of select="umbraco.library:NiceUrl($node/@id)"/> </xsl:otherwise> </xsl:choose> </xsl:attribute> <!-- Set the title attribute if available from the properties --> <xsl:if test="string($node/navTooltip) != ''"> <xsl:attribute name="title"> <xsl:value-of select="string($node/navTooltip)"/> </xsl:attribute> </xsl:if> <!-- Set actual text for the link, either available from the properties or just plain umbraco link--> <xsl:choose> <xsl:when test="string($node/navText) != ''"> <xsl:value-of select="string($node/navText)"/> </xsl:when> <xsl:otherwise> <xsl:value-of select="$node/@nodeName"/> </xsl:otherwise> </xsl:choose> </a> </xsl:otherwise> </xsl:choose> </xsl:otherwise> </xsl:choose>
//Function is taken from XSLTSearch by Douglas Robar from Percipient Studios (http://www.percipientstudios.com/) public string ReadMacroParameter(string value, string defaultValue) { if (value == "") return defaultValue; else return value.Replace(" ", ""); }
//Function fixes a possible wrongly formatted link public string FixLink(string oldLink) { string newLink = string.Empty;
if (!oldLink.StartsWith("/")) newLink += "/"; newLink += oldLink; if (!oldLink.EndsWith(".aspx")) newLink += ".aspx";
so, say on Home, Schedule and who we are links, normal contenet page will open. But on Downloads link I want to show mega menu in which books, videos, songs links with some text and img will be displayed.
mega menu
hello all.
I am using umbraco 4.7. I am new to umbraco.
On my website, I want some of the top navigation menu items to appear as mega menu. can I do this using xslt? please help.
Hey,
Rich
Hi there, I am doing exactly this, would like to see the code please.
Regards
Praveen
Sample Code:
<!DOCTYPE xsl:stylesheet [
<!ENTITY nbsp " ">
<xsl:stylesheet version="1.0"
xmlns:msxsl="urn:schemas-microsoft-com:xslt"
xmlns:netaddicts-be="urn:netaddicts-be:xslt"
exclude-result-prefixes="msxml umbraco.library netaddicts-be">
<xsl:choose>
<xsl:call-template name="buildTopNavigation">
<xsl:with-param name="navigationNodes" select="umbraco.library:GetXmlNodeById($startNodeId)"/>
</xsl:when>
<xsl:otherwise>
<!-- Start building navigation from top level node -->
<xsl:with-param name="navigationNodes" select="umbraco.library:GetXmlAll()"/>
</xsl:otherwise>
</xsl:choose>
</xsl:template>
<!-- Start building the top navigation (first level navigation) -->
<xsl:template name="buildTopNavigation">
<xsl:param name="navigationNodes"/>
<xsl:variable name="NoOfChildren" select="count($navigationNodes/child::* [@isDoc][string(umbracoNaviHide) != '1'])" />
<ul>
<!-- Iterate child nodes -->
<xsl:for-each select="$navigationNodes/child::* [@isDoc]">
<xsl:choose>
<li>
</xsl:if>
</li>
</xsl:when>
<xsl:otherwise>
<li class="last">
</xsl:if>
</li>
</xsl:otherwise>
</xsl:choose>
</xsl:if>
</xsl:for-each>
</ul>
</xsl:template>
<ul>
<li>
<xsl:if test="
</xsl:if>
</li>
</xsl:if>
</xsl:for-each>
</ul>
</xsl:template>
<xsl:choose>
<xsl:call-template name="buildExternalLink">
<xsl:with-param name="node" select="$* [@isDoc]"/>
</xsl:when>
<!-- Build link for redirecting to a custom supplied url -->
<xsl:when test="string($node/umbracoRedirect) != ''">
<xsl:call-template name="buildRedirectLink">
</xsl:when>
<!-- Default link builder -->
<xsl:otherwise>
<xsl:call-template name="buildNormalLink">
</xsl:otherwise>
</xsl:choose>
</xsl:template>
<a Target="_blank">
</xsl:attribute>
</xsl:attribute>
</xsl:if>
</xsl:attribute>
</xsl:if>
<xsl:choose>
</xsl:when>
<xsl:otherwise>
</xsl:otherwise>
</xsl:choose>
</a>
</xsl:template>
<xsl:template name="buildRedirectLink">
<a>
</xsl:attribute>
</xsl:attribute>
</xsl:if>
<xsl:choose>
</xsl:when>
<xsl:otherwise>
</xsl:otherwise>
</xsl:choose>
</a>
</xsl:template>
<xsl:template name="buildNormalLink">
<xsl:choose>
<xsl:choose>
<xsl:choose>
</xsl:when>
<xsl:otherwise>
<xsl:choose>
</xsl:if>
</xsl:for-each>
</xsl:when>
<xsl:otherwise>
</xsl:otherwise>
</xsl:choose>
</xsl:otherwise>
</xsl:choose>
</xsl:attribute>
</xsl:attribute>
</xsl:if>
<xsl:choose>
</xsl:when>
<xsl:otherwise>
</xsl:otherwise>
</xsl:choose>
</a>
</xsl:when>
<xsl:otherwise>
<a class="active">
<xsl:choose>
</xsl:when>
<xsl:otherwise>
</xsl:otherwise>
</xsl:choose>
</xsl:attribute>
</xsl:attribute>
</xsl:if>
<xsl:choose>
</xsl:when>
<xsl:otherwise>
</xsl:otherwise>
</xsl:choose>
</a>
</xsl:otherwise>
</xsl:choose>
</xsl:when>
<xsl:otherwise>
<xsl:choose>
<xsl:choose>
</xsl:when>
<xsl:otherwise>
<xsl:choose>
</xsl:if>
</xsl:for-each>
</xsl:when>
<xsl:otherwise>
</xsl:otherwise>
</xsl:choose>
</xsl:otherwise>
</xsl:choose>
</xsl:attribute>
</xsl:attribute>
</xsl:if>
<xsl:choose>
</xsl:when>
<xsl:otherwise>
</xsl:otherwise>
</xsl:choose>
</a>
</xsl:when>
<xsl:otherwise>
<a>
<xsl:choose>
</xsl:when>
<xsl:otherwise>
</xsl:otherwise>
</xsl:choose>
</xsl:attribute>
</xsl:attribute>
</xsl:if>
<xsl:choose>
</xsl:when>
<xsl:otherwise>
</xsl:otherwise>
</xsl:choose>
</a>
</xsl:otherwise>
</xsl:choose>
</xsl:otherwise>
</xsl:choose>
</xsl:template>
<!-- For debugging purposes, writes out all relevant node properties -->
<xsl:template name="outputNode">
<xsl:param name="currentNode"/>
<ul>
<li>
@id=<xsl:value-of select="$currentNode/@id"/>
</li>
<li>
@nodeName=<xsl:value-of select="$currentNode/@nodeName"/>
</li>
<li>
@umbracoNaviHide=<xsl:value-of select="$currentNode/umbracoNaviHide"/>
</li>
<li>
@umbracoHideChildren=<xsl:value-of select="$currentNode/umbracoHideChildren"/>
</li>
<li>
@navText=<xsl:value-of select="$currentNode/navText"/>
</li>
<li>
@navTooltip=<xsl:value-of select="$currentNode/navTooltip"/>
</li>
<li>
@externalURL=<xsl:value-of select="$currentNode/externalURL"/>
</li>
<li>
@externalTarget=<xsl:value-of select="$currentNode/externalTarget"/>
</li>
<li>
@umbracoRedirect=<xsl:value-of select="$currentNode/umbracoRedirect"/>
</li>
<li>
@umbracoUrlAlias=<xsl:value-of select="$currentNode/umbracoUrlAlias"/>
</li>
</ul>
</xsl:template>
<msxsl:script language="C#" implements-prefix="netaddicts-be">
<![CDATA[
if (value == "")
else
newLink += "/";
newLink += oldLink;
newLink += ".aspx";
return newLink;
</msxsl:script>
</xsl:stylesheet>
hi Rich Green,
I have still not started the mega menu, so not having markup. But I want to develop menus like http://www.foodnetwork.com/ or http://www.actionenvelope.com/
my site structure is something like.....
-My Website
-- Home
-- Downloads
-- Books
-- Videos
-- Songs
-- Schedule
-- Who we are
