  • Niels Henriksen 13 posts 25 karma points
    Jun 26, 2011 @ 21:06
    Niels Henriksen
    [4.7] CSS in Richtext editor
    I have made a css file and included that in "Developer" - "Datatype" - "Richtext editor". But the styles dont appear in the dropdown?
    Jun 26, 2011 @ 21:25
    Kim Andersen
    Hi Niels
    If you want to have some styles in the drop down you actually need to do one more thing. You must create the styles that you want as children to the stylesheet that you've attached to the richtext editor. This means going to the Settings section and right click the stylesheet you attached to the editor. Now you can create all of the styles tht you need in the drop down.
    I hope it makes sense to you Niels.
    /Kim A
    Jun 26, 2011 @ 21:29
    Niels Henriksen
    Hi Kim
    How stupid of me.... that was also what I have done before :(
    /Niels
    Jun 26, 2011 @ 21:37
    Kim Andersen
    No problem :)
    The main stylesheet that you create is for the styling inside of the richtext editor, but you probably already know this :)
    By the way, if you can mark this post as solved it would be great.
    /Kim A
    Jun 26, 2011 @ 21:42
    Niels Henriksen
    How to mark it solved?
    Jun 26, 2011 @ 21:44
    Kim Andersen
    Under each answer that's not your own, there's a small green tich that you can click to select the correct solution for your answer.
    /Kim A
  • sravani 50 posts 70 karma points
    Jun 28, 2011 @ 10:22
    sravani
    Hi Kim,
    Thanks for sharing your solution. Much appreciated.
    Regrads,
    Sravani
    Jun 28, 2011 @ 20:48
    Kim Andersen
    You're welcome Sravani. I'm glad that you can use my answers :)
    /Kim A
