  • dominik 711 posts 733 karma points
    Jun 27, 2011 @ 16:53
    dominik
    Move dictonary items
    I can create a child dictonary item. This is good to keep the dictonary items clear.
    But if i want to reorganize the items i have sometimes to move one folder into another folder or one dictonary item into another dictonary items.
    This is not possible so i have to delete each item and create a new item.
    Is there any solution to solve this?
    Jun 28, 2011 @ 12:26
    dominik
    Any solution / bugfix for it?
    Jun 28, 2011 @ 12:30
    Dirk De Grave
    I don't think there's a solution to this other than delete the old and create the new item I'm afraid (unless you know something about the database structure, in which case you may check how dictionary items are stored and maybe change some ids - altho not the preferred way, it may work... BACKUP first if you do give it a try). Can always suggest a feature item on Codeplex...
    /Dirk
    Jun 28, 2011 @ 12:32
    dominik
    ok i will suggest it as a feature - thanks
    This would be really a nice feature
