  • CMSPlusHosting 9 posts 29 karma points
    Jun 28, 2011 @ 06:56
    CMSPlusHosting
    Tabs not showing?
    I created new document type, added properties for that type. The document type is a sub of the "master" parent; Is there any reason why the properties and tabs I entered in the document type aren't showing? I could enter it in the master parent doc type, but not the sub ones. Inheritance problem?? Or something I may be missing?
  • Richard Soeteman 4052 posts 12925 karma points MVP 2x
    Jun 28, 2011 @ 08:03
    Richard Soeteman
    It's displayed on the top of your sub doctype that these properties will not be showed in the subtype. It's by design in Umbraco. If you want to have more flexibility you might want to checkout the DocTypeMixins package.
    Richard
