Switch dbType from Nvarchar to Ntext without data loss
On one of my Umbraco installs, I'd like to switch a data-type from using the old Tree Multi Picker control to the uComponents MultiNode Tree Picker control. The problem I have is that I originally set the underlying dbType to Nvarchar - and I know that MNTP uses Ntext to store the data/value.
Quick test of this shows that the data/value doesn't persist across Nvarchar and Ntext ... so the question is how to best do this?
I did find an old forum topic about this, but there was no real solution - aside from "hacking around in the database tables". I could easily do this myself - but I'm hoping that there's a more elegant answer out there ... even if it means that we need to create a new package/dashboard-control for it.
Any ideas, suggestions? (Hoping there's a package out there that already does this)
Following up on my own topic... I ended up doing a SQL UPDATE on the cmsPropertyData table:
UPDATE
cmsPropertyData
SET
dataNtext = dataNvarchar
FROM
cmsPropertyData AS d
INNER JOIN
cmsPropertyType AS t ON t.id = d.propertytypeid
WHERE
d.dataNvarchar IS NOT NULL
AND
d.dataNvarchar != ''
AND
t.Alias = 'promoNodes'
Didn't have time to build a nice UI for this functionality ... if any one wants to develop something like this, you're free to use this code snippet.
Thanks, Lee.
UPDATE cmsPropertyData SET dataNtext = dataNvarchar FROM cmsPropertyData AS d INNER JOIN cmsPropertyType AS t ON t.id = d.propertytypeid WHERE d.dataNvarchar IS NOT NULL AND d.dataNvarchar != '' AND t.Alias = 'promoNodes' ;Didn't have time to build a nice UI for this functionality ... if any one wants to develop something like this, you're free to use this code snippet.
Cheers, Lee.
Thanks a lot for this Lee, it got me on the right track.
