  • chris 69 posts 92 karma points
    Jun 30, 2011 @ 22:28
    chris
    adding open ldap
    I have a umbraco install 4.0.4.2 and it is tied in to active directory, which I use to authenticate internal users to update the content in the site.
    I'd like to add certain section in the website that requires authentication for outside users. Is there a way to add open ldap for internet users in addition to the active directory? How do I get to do this?
  • Johannes Fischer 1 post 21 karma points
    Oct 12, 2011 @ 00:08
    Johannes Fischer
    I'm interested in your internal authentication set-up. Would you mind explaining how you set this up? Thanks!
    Oct 17, 2011 @ 06:03
    chris
    I'm using active directory for internal authentication. It's the standard procedure, I believe there is a documentation and samples already. You can look up on that one.
