I have two problems with the Rich Text Editor when inserting macros:
1. If I insert a macro that when it displays has an empty div then when I save it the macro dissapears.
2. If I insert a macro and save it always adds two <br /> elements at the end of the text.
The first problem isn't so important I have added some text and used text-indent to make it dissapear.
The second problem is just annoying and if anyone knows a fix for it please let me know!
ThanksBen
See http://umbraco.codeplex.com/workitem/30534
Macros in RTE
Ben
