SpeechBubbles are empty after redirect in BackOffice
I attach to the /umbraco/default.aspx load event to redirect to /umbraco/umbraco.aspx so I can attach to the umbraco.aspx load event and add custom javascript.
I've done this before, but every time, it breaks the speechbubbles (i.e. blank .. see image)
How can I add my custom javascript to umbraco.aspx and not break the speechbubbles..
This is the code I use to redirect to /umbraco/umbraco.aspx.. it breaks the SpeechBubbles:
if (application.Context.CurrentHandler is _Default)
// default.aspx forwards to umbraco.aspx with Server.Transfer so redirect is required
// in order to process code below
var umbPath = string.Format("{0}/umbraco.aspx", GlobalSettings.Path);
try
// try "/umbraco" path
application.Response.Redirect(umbPath);
catch
// transfer as normal
application.Server.Transfer(umbPath);
return;
