  • Adrian Bonnici 2 posts 22 karma points
    Jul 05, 2011 @ 12:33
    Adrian Bonnici
    3-tier architecture in Umbraco possible?
    Hi guys,
    I finished coding a blog as software project 3-tier architecture. This means that the project is split into the:
    • Presentation Layer (ASP.Net/HTML)
    • Business Layer (C# - The logic of all the site)
    • Data Layer (Contains adapters adn datasets to interface with a database)
    For now i managed to port my custom user controls using macros. The problem i am facing is that i have no idea how to combine my project with umbraco.
    Do i have to put the C# code files that are found in the business layer  in seperate XLST files?
    Also how can i upload my Microsoft SQL Server Database file (.mdf) into umbraco?
  • Michael Latouche 504 posts 819 karma points MVP 4x c-trib
    Jul 05, 2011 @ 13:35
    Michael Latouche
    Hi Adrian,
    What do you want to achieve exactly : do you want to "migrate" your blog software into Umbraco, or do you want it to run separately,  side by side with Umbraco?
    Michael.
    Jul 05, 2011 @ 14:09
    Adrian Bonnici
    Hi, thanks for the reply just found out that blog4umbraco exsists! Im goin to create my own skin for blog4umbraco based on my current software project.
    Jul 05, 2011 @ 14:16
    Michael Latouche
    Great :-)
    Have fun!
    Michael.
  • Abhishek 11 posts 52 karma points
    Nov 12, 2015 @ 12:02
    Abhishek
    Hey, Wanted to check, I just got stuck up with the same issue where I need to split Umbraco into three project UI, AppServerice and Database.
    Is it possible ?
