  • chris 69 posts 92 karma points
    Jul 06, 2011 @ 18:49
    chris
    How do I use tags?
    I have Umbraco 4.0.4.2. I'm trying to use the tags datatype, using the basic xslt from the site map.
    The site has this structure:
    -Articles
    -Article 1    ;has a tag "Arts"
    -Article 2    ;has a tag "Science"
    -Categories
    -Arts         ;clicking here will list all articles that has "Arts" tag
    -Science    ;clicking here will list all articles that has "Science" tag
    So I'd insert a macro under Categories\Arts and it will search everything under Articles and list the ones that has 'arts' tag.
    <xsl:template match="/">
    <ul>
    <xsl:apply-templates select="$currentPage/node" />
    </ul>
    </xsl:template>
    <xsl:template match="node">
    <li>
    <xsl:value-of select="@nodeName" />
    </a>
    </li>
    </xsl:template>
    <xsl:template match="node[data[@alias = 'umbracoNaviHide'] = 1]" />
    How do I get the xslt to point to the Articles node and start grabbing all articles, and sort it out by the specified tags?
    Jul 06, 2011 @ 20:37
    chris
    Nevermind this, I figured it out by using this:
      <xsl:param name="ArticleNode" select="umbraco.library:GetXmlNodeById(1000)" />
      <xsl:param name="dTags" select="/macro/pTags" />
        <ul>
          <xsl:for-each select="$ArticleNode/node [string(data [@alias = 'umbracoNaviHide']) != '1' and contains(data[@alias='pageTags'], $dTags)]">
            <xsl:sort select="@updateDate" order="descending"/>
            <li>
              </a>
            </li>
          </xsl:for-each>
        </ul>
      </xsl:template>
