umbracoHideTopLevelNodeFromPath not working (randomly)
Under the Content folder, I have a single document called My Website which represents the root and home page of my website. Below it are all other pages. To make sure that my-webiste/ isn't included in the document url, I've set umbracoHideTopLevelNodeFromPath to true. This works for a while and then mysteriously, and only for some urls, my-website/ is output in the url from the NiceUrl call. This wouldn't be so bad if when the user clicks on the link they didn't get a 404. Re-publishing the website seems to fix the problem temporarily but then after an hour or two the problem creeps back. I've seen the problem mentioned in the forums but no satisfactory explanation or solution. I'm using Umbraco 4.7. Is there something I may have setup incorrectly? If it's a bug, can we expect a fix soon?
I'm getting the exact same issue on one of my pages in Umbraco 4.7. It intermittently keeps prepending 'home' to the url - resulting in a 404 error. This is only happening on one page. What's bizarre is that I've actually deleted the page and recreated it.
The only thing different I am doing in this page is calling umbraco.library.NiceUrlFullPath.
Republishing temporarily fixes the url, but it seems to revert back to 'home' although it's very difficult to recreate.
So I changed the umbraco.library:NiceUrlFullPath to umbraco.library:NiceUrl calls and everything seems to be better. I haven't had a node revert back to having /home/ in it's URL yet.
Defenatly seems to be a bug in umbraco.library:NiceUrlFullPath
I'm still seeing this bug crop up whether I'm using Url, NiceUrl, or NiceUrlFullPath. Clients are getting irritated and it's making Umbraco look bad to my boss. I upgraded to 4.7.1 hoping it would be fixed but no such luck. Please fix in 4.7.2.
We recently came across this problem also. The "Link to document" included the /home path and any links resulting from NiceUrl or NiceUrlFullPath included the /home path.
Our testing showed that if we checked the "Hide from Navigation" box on the Home node this no longer appeared in the path. Pbulish the home node, and also publish any other nodes which are being affected to clear the 'umbraco caching' causing the issue to persist.
I have this problem too (in 4.7.2) but I think it is to do with the creation of the url and not NiceURL because (in my case anyway) the "Link to document" on the Properties tab of the badly linked page(s) also shows the root node.
A temporary fix seems to be to re-publish any page which has the problem and the "home" node disappears from the URL.
This fix seems to also work if you Publish an ancestor node and select to publish all children BUT doing a global publish from the root node doesn't do the fix.
So my workaround is to go through every child of the root and re-publish with children whenever I see the problem occur.
I have just observed this strange behavoir for the first time in a Umbraco 4.9 installation. I have created a bug report at http://issues.umbraco.org/issue/U4-1058 Please vote if you would like to see this issue addressed.
Ugh, just did a fresh 4.9.0 install (SQL Server 2008) and am getting this problem. Although for me, it's not random, it's quite consistent. Cannot access the root of the domain because I get a 404. I have to go to www.example.com/home which is not what I want!
Oh, I think the problem is because I published a sibling to my homepage (i.e., a node at the same "level" which sits under/after the homepage), which appears to have taken over "/" as its URL. Even though we have homepage as the first node in the tree and this other node appearing second, I think this is related to the agonizing sort bug U4-888?
See my comments on U4-888 and U4-1058. We're refactoring that part heavily in 4.10 and it should now at least produce a consistent behavior.
The node that answers to "/" will be the first node in the tree ie the one with the lowest @sortOrder value.
That being said, when you do
Home Page 1 Page 2
With hideTopLevelNodeFromPath, the urls are /home, /page-1 and /page-2. The fact that url "/" also routes to Home is something that we cannot break but that really is an accident. In 4.10 NiceUrl will return /home as the url for node Home.
The correct way to setup the website should be:
Home - Page 1 - Page 2
with hideTopLevelNodeFromPath set to true.
That being said, should you want to keep the former structure, 4.10 should guarantee that at least url "/" always route to Home, provided it remains on top of the tree.
Thank you
Any help would be appreciated.
I am also having the same issue on multiple sites with 4.7 that use the same base package and call NiceUrl, see below.
I also access the page using EyeCatch RSS which makes umbraco.library:NiceUrlFullPath calls
Also posted this question on StackOverflow about a month ago, with no answer. http://stackoverflow.com/questions/7197503/umbraco-urls-displaying-home-node-in-one-node-sometimes
DOCTYPE xsl:stylesheet [ ENTITY nbsp ""> ]>
<xsl:stylesheet
version="1.0"
<xsl:variable name="maxItems" select="/macro/maxItems" />
<xsl:template match="/">
<ul class='newsList'>
<xsl:for-each select="$currentPage/* [@isDoc and string(umbracoNaviHide) != '1']">
<xsl:if test="position() >
Cheers
Any solution for this?
I'm using 4.7.2 but the issue still exists... :(
Thanks!
Does anyone know if it got fixed in 4.8?
Home
Page 1
Page 2
Home
- Page 1
- Page 2
