We have tons of documents and images in the Media section. How do we find out what pages link to them or if nothing links to them?
This would help tremendously in removing files we no longer need and cleaning out duplicative files by having pages link to the same one.
Hey Jennifer,
Not used it, but this could be what you need
http://our.umbraco.org/projects/backoffice-extensions/thefarm-media-link-checker
Rich
Thanks. Unfortunately that requires that you're still running under the legacy schema. Otherwise it sounds like exactly what I need.
Hi Jennifer,
Even if you use an Umbraco version, which normally uses the new XML schema from Umbraco version 4.5, it is possible to switch Umbraco to use the legacy schema. Through this guide, you can change the XML schema.http://our.umbraco.org/wiki/reference/xslt/45-xml-schema/switching-between-old-and-new-schema
Hope it can help you.
/Dennis
Thanks Dennis, but we have other things running on the site that require the new schema, so we can't switch.
Okay, I can see that it´s not a possible solution to change the XML schema, when other things on the site is required the new schema.
But now you know that it can be done, if you need it one day :-).
how to find what links to files?
Hey Jennifer,
Rich
Hi Jennifer,
/Dennis
Hi Jennifer,
/Dennis
