The new 4.5.2 accordion doesnt seem to like links in it! When I replicate the U3 accordion in U4, I paste into the Item 1 Title - Case studies, and into the Item 1 text an unordered list of 4 links and Save/Publish.
The result is that everything following the first href= is stripped out and the UL is gone.
I've tried both single and double quotes (round the link) as thats where the code is stripped from, but nothing makes a difference
The accordion functionality has nothing to do with the version of Umbraco you are using. The HTML, CSS and JavaScript are not tied to Umbraco in anyway so there must be something else going wrong somewhere.
Could you post the snippet of JavaScript that should make the accordion effect? And could you also post the code you are using to generate the lists?
I understand what you are saying but I am trying to use the Accordion macro (developer/macros/accordion which uses the developer/xslt/accordion.xslt) which I assumed was a standard macro!
As it works fine without any links in it I didnt look to hard at the xslt, but upon further investigation, it uses a class accordion which I cant find in any of the style sheets so I'm not too sure how that works!
U4.5.2 Accordion
Probably a simple answer to what seems a simple question but I cannot find anything about the problem.
Trying to create an accordion just like the ones on http://www.fusioninternetsolutions.com/web-application-development.aspx (Umbraco 3) .
Hopefully someone can help
Cheers
Dave
Hi Dave
Hi Jan
Cheers
Dave
Just found the Accordion JS buried in a .js file!
window.addEvent('domready', function() {
//create our Accordion instance
var myAccordion = new Accordion($('accordion'), 'h3.toggler', 'div.element', {
opacity: false,
onActive: function(toggler, element){
toggler.addClass('accopen');
toggler.removeClass('accclosed');
onBackground: function(toggler, element){
toggler.addClass('accclosed');
toggler.removeClass('accopen');
Dave
Hi Dave
Nope, accordions are not in the standard macroes in Umbraco :-)
So I guess you found the missing link now?
Hi Jan
Yes, looks like its some code a previous developer here created.
Sorry I messed you about!!
Dave
Hi Dave
No worries, we are here to help each other out - and you managed to figure out what was wrong, right? :-)
Everyone gets a bit confused now and then - especially when the clock is ticking.
Happy to see you got it sorted.
