  • dominik 711 posts 733 karma points
    Jul 21, 2011 @ 09:37
    dominik
    TinyMCE css class dorpdown for links
    How can i add the css styles dropdown also to the "insert link" popup.
    I need this to add a lightbox class which opens the URL in a lightbox
    Jul 21, 2011 @ 10:32
    dominik
    So inside the link.html there is a class dropdown but this is not shown. How can i show this in TinyMCE and let the user choose one class for the link (<a> tag)?
  • Mike Chambers 636 posts 1253 karma points c-trib
    Jul 21, 2011 @ 10:34
    Mike Chambers
    umbraco\plugins\tinymce3\insertLink.htm
    Is where you probably need to start. The customised umbraco version has the styles box that you would get by default with TinyMce removed.
    However it is a bit more involved as that will only add a styles drop down of all your styles in the associated css file for the tinymce editor and not styles that you have set in the umbraco stylesheet create proceedure.
    Jul 21, 2011 @ 10:35
    dominik
    But why is this removed? Is there no setting to get this work?
