  • Chris Dunn 210 posts 401 karma points
    Jul 21, 2011 @ 22:41
    Chris Dunn
    Can't Sort Nodes/ Duplicate Sort Order
    Having some problems with a site which prevents certain nodes from be sorted.  When viewing the sort dialog the sort order of some elements are duplicated...two nodes with sort order 1.
    I am able to sort certain nodes but others save with no errors but the changes are not applied.
    I know there were some issues on previous versions of Umbraco that should be fixed now according to codeplex.  The site is running 4.7.
    Any thoughts?
    Chris
    Jul 24, 2011 @ 02:30
    Chris Dunn
    Just a follow up to my post.  I republished the parent node/children and the sort order was corrected and I was able to sort again.  Still not certain why it happens but I am guessing a database timeout or un-logged error of some sort causing the sort process to terminate part way through the process, leaving some sort orders updated and not others.
    -Chris
