    Jul 23, 2011 @ 15:01
    Anthony Candaele
    ImageGen not working with macro parameter
    I have a .Xslt file 'screenshot.xslt' where I want to rezise an image using ImageGen.
    my code looks like this:
    <xsl:variable name="image" select="/macro/image/Image/umbracoFile" />
    <xsl:if test="string-length($image) &gt; 0">
      <id="single_image" href="{$image}" title="{$title}"><img src="ImageGen.ashx?image={$image}" width="200" /></a>
    </xsl:if>
    for some reason this does not work. If I delete the ImageGen code like this:
      <id="single_image" href="{$image}" title="{$title}"><img src="{$image}" width="200" /></a>
    </xsl:if>
    the thumbnail image is shown in the page.
    Does anyone has an idea why ImageGen doesn't work with this macro parameter?
    Thanks for your help,
    Anthony
    Jul 23, 2011 @ 15:39
    Kim Andersen
    Hi Anthony
    I think you're not giving the right path to the ImageGen.ashx-file. I think you need the slash in front of the path like this:
    <img src="/ImageGen.ashx?image={$image}&amp;width=200" width="200" />
    /Kim A
    Jul 23, 2011 @ 16:13
    Anthony Candaele
    Hi Kim,
    You're right. Thanks a lot. I'm currently editing the Umbraco Cms pages on my website: http://www.webmove.be/startpagina/umbracocms
    The screenshot.xslt is for showing the screenshot pictures in the right column as you can see on subsequent pages:
    http://www.webmove.be/startpagina/umbracocms/versiebeheer
    http://www.webmove.be/startpagina/umbracocms/meertaligheid
    and http://www.webmove.be/startpagina/umbracocms/veiligheid
    I don't want to take full credit for this layout, as I was inspired a lot by : http://www.webs.be/diensten/webdevelopment/cms.aspx :)
    greetings,
    Anthony
    Jul 23, 2011 @ 17:48
    Kim Andersen
    Ahh yeah, I can see where you are using it :)
    And you are welcome Anthony - anytime ;)
    /Kim A
