  • Sean 64 posts 116 karma points
    Jul 23, 2011 @ 19:44
    Sean
    URL Redirecting to transition from old site (wordpress)
    What is the best way, in Umbraco, to redirect a url from the old values (cached by Google, other sites etc)? So in effect, it would be:
    OLD: domain.com/category/First-Item/First-time-child/
    NEW: domain.com/english/First-Item/
    I just want to do simple redirect on the URL, there are quite a few of them though.
    Sean.
    Jul 24, 2011 @ 13:57
    Dirk De Grave
    Sean,
    Either take a look at urlrewriting.net, which is available in umbraco out of the box (just need to add your rules to the urlrewriting.config in /config folder), or this project.
    Hope this helps.
    Regards,
    /Dirk
    Jul 30, 2011 @ 20:07
    Sean
    Thanks Dirk for the info, I actually just went ahead and used the URL rewerite 2.0 module in IIS 7.5. I wonder if I would get better performance using urlrewriting.config.
    -Sean
