  • David F. Hill 122 posts 242 karma points
    Jul 23, 2011 @ 22:26
    David F. Hill
    Custom Umbraco Section problem with edit aspx
    Hello Umbraco Colleagues,
    I'm trying to create a custom section by following Tim's example on umbraco.tv.
    Everything works except the editCorporateCompliance.aspx page.
    None of the controls with the "umb" prefix are recognized - thus it will not compile.
    I'm using Umbraco 4.7.0.
    Here is my code:
    <%@ Page Language="C#" MasterPageFile="/umbraco/masterpages/umbracoPage.Master" AutoEventWireup="true" CodeBehind="editCorporateCompliance.aspx.cs" Inherits="CustomTree.editCorporateCompliance" %>
    <%@ Register TagPrefix="umb" Namespace="umbraco.uicontrols" Assembly="controls" %>
    <asp:Content ID="Content" ContentPlaceHolderID="body" runat="server">
    <umb:UmbracoPanel ID="Panel1" runat="server" hasMenu="true" Text="Edit Corporate Compliance">
    <umb:Pane ID="Pane1" runat="server">
    <umb:PropertyPanel ID="PPanel1" runat="server" Text="Wrong word">
    <asp:TextBox ID="txtWrongWord" runat="server" MaxLength="150"
    CssClass="guiInputText guiInputStandardSize"></asp:TextBox>
    </umb:PropertyPanel>
    <umb:PropertyPanel ID="PPanel2" runat="server" Text="Correct word">
    <asp:TextBox ID="txtCorrectWord" runat="server" MaxLength="150"
    <umb:PropertyPanel ID="PPanel3" runat="server" Text="Cause">
    <asp:TextBox ID="txtCause" runat="server" TextMode="MultiLine"
    </umb:Pane>
    </umb:UmbracoPanel>
    </asp:Content>
    I saw one post on Stack Overflow that suggested adding a reference to ClientDependency.Core but that didn't help.
    I can't see what I'm doing wrong.
    If anyone has gotten this to work, could you help me out and/or post the solution?
    David
    Jul 25, 2011 @ 18:15
    David F. Hill
    Update:
    I got the application working simply by recreating the editCorporateCompliance.aspx page. I cannot say with certainty what the issue might have been.
    I will say the example on .tv (http://umbraco.com/help-and-support/video-tutorials/developing-with-umbraco/custom-sections,trees-and-pages/creating-edit-pages) works well.
    David
