  • Tom Madden 253 posts 455 karma points MVP 4x c-trib
    Jul 24, 2011 @ 23:16
    Tom Madden
    Sorting Prevalues by dragging in 4.7 - is it working for anyone
    I noticed 4.7 has an option to sort prevalues, but when I try to do this it just selects the text on the page. I tried this in Firefox, Safari, Chrome, IE (all on PC). Has anyone had manual sorting of prevalues in 4.7 working for them, or is it just me?
    TIA
    Tom
    Jul 25, 2011 @ 13:50
    Tom Madden
    After a lot of testing (including installing dev versions of browsers and updating browsers) I found out the following:
    If you include brackets inside of a prevalue (normal brackets, like these), then you can't edit the values in your prevalue list, starting from the first item containing brackets, to the end of the list.
    You will not be able to sort your prevalues by dragging, until you delete those items with brackets (remember you can't edit the value either).
    Sorting and editing will then work as normal.
    If you come across this issue, please vote up this codeplex issue
    http://umbraco.codeplex.com/workitem/30375
