    Jul 25, 2011 @ 14:29
    Anthony Candaele
    selectively adding text between <a> tags in Xslt
    I was working on an Xslt script, when the need arose to selectively put text between <a> href tags in Xslt.
    Say I have this Xslt code:
    <p><xsl:value-of select="$sometext"/><p>
    Depending on whether or not a user inputted an url in a macrocontainer, the text should be wrapped by a <a> tag:
    <p><a href="{$someurl}"><xsl:value-of select="$sometext"/></a><p>
    I was think first in solving this with  <xsl:attribute> but this only adds, by my knowing, attributes to the <a> element, unless there would also be an attribute like 'innerhtml' or something.
    An other solution maybe would be possible with an <xsl:template> , but I'm not an Xslt expert, hence my question on this forum :)
    Thanks for the advice,
    Anthony
    Jul 25, 2011 @ 15:17
    Dirk De Grave
    Anthony,
    I guess a simple xsl:choose would work?
    <p>
    <xsl:choose>
    <xsl:when test="$someurl">
    </xsl:when>
    <xsl:otherwise>
    </xsl:otherwise>
    </xsl:choose>
    </p>
    /Dirk
    Jul 25, 2011 @ 15:32
    Anthony Candaele
    Hi Dirk,
    Just tried your code, and my problem is solved :)
    Thanks a lot,
    Anthony
