Then we have several aspx pages with register in their OnInit Event which tabs needs to be created and which user controls in the form of a subform usercontrol needs to be added to it, example:
Now when the code is run. The tabs are and the pane with its controls are shown like they are supposed to. Only one slight problem: The Menu is not rendered properly. There are no buttons visible and even the scrolling arrows on either side of the menu are not visible. The strange thing is when a postback to the server is performed the menu IS rendering properly and the buttons work just fine.
After fiddling around for a day i cant figure out why the menu is not rendered properly the first time. It can't be that hard to build a tabpage dynamically.
TabView not rendering its menu properly
Heey,
We have a problem with a tabview not rendering its ScrollingMenu component properly. Our structure is like thus:
We have a MasterPage with the TabView on it:
<cc1:TabView runat="server" ID="tabView" AutoResize="false" Width="800px" Height="400px" />
protected override void OnInit(EventArgs e)
base.OnInit(e);
Master.TabControl.RegisterSubFormTab(EventsPane,EventsForm, "Events");
Master.TabControl.RegisterSubFormTab(EmployeePane, EmployeeForm, "Employees");
The function itself adds the tab to be created in a list.
On the OnLoad() event of the MasterPage another function is called that loops through the list and adds the tabs to the tab view like so:
private void AppendTab(AdminTab tab)
tab.Control.TabPage = UmbracoTabComponent.NewTabPage(tab.Name);
tab.Control.TabPage.HasMenu = true;
tab.Control.TabPage.Controls.Add(tab.Pane);
There is another piece of code that add adds buttons to the menu:
private void CreateMenuButton(out ImageButton btn, ImageClickEventHandler handler, string toolTip, string imgUrl, bool causesValidation, string validationgroup = null)
btn = TabPage.Menu.NewImageButton();
btn.ID = TabPage.Menu.ClientID + "_" + toolTip;
btn.Click += new ImageClickEventHandler(handler);
btn.ToolTip = toolTip;
btn.AlternateText = toolTip;
btn.ImageUrl = imgUrl;
btn.Visible = false;
btn.ValidationGroup = validationgroup;
btn.CausesValidation = causesValidation;
