  • Floffy 26 posts 33 karma points
    Jul 26, 2011 @ 21:46
    Floffy
    Tiny MCE Styles do not render in editor
    On a Umbraco 4.7.0, i created a custom datatype based on a Tine MCE 3.
    Added two related stylesheets
    Styles availeble in dropdown, but do not render in the editor. On the sites the styles are showing, bur it makes it didicult for the editots.
    Did I miss something?
    Jul 27, 2011 @ 00:05
    Hi Floffy
    Where have you defined the styles for the elements etc. ?
    You need to use .mceContentBody X (p, h1, h2 etc. for instance) as a selector for the stuff inside the Umbraco rich text editor to have the same styles as it has on your website.
    Hope this makes sense.
