I am developing website using umbraco cms. I have xml file in project root folder. And I am reading xml file in my xslt file. Right now i am hardcoded the full file path like document("D://ProjectFoldername/test.xml).now its working good.
I need how to give file path as ('test.xml').but is showing error error in reading _.xslt file
relative path and server.mappath in xslt
Please suggest be better solution
Hi selva,
You could use
<xsl:variable name="xmlFromUrl" select="umbraco.library:GetXmlDocumentByUrl('http://www.domain.com/test.xml')" />which returns an XPathNodeIterator
From there on, you can query your xml as you'd normally would in xslt.
/Dirk
