  • mark firth 32 posts 75 karma points
    Jul 29, 2011 @ 16:39
    mark firth
    Mulit Level Drop down Menu using Razor in Umbraco
    Hi, I am trying to build a multi-level dropdrown menu, I'm using umbraco cms.
    What I am looking for is something like which works perfectly in html
                     $(document).ready(function () {
                         $('.myMenu > li').bind('mouseover', openSubMenu);
                         $('.myMenu > li').bind('mouseout', closeSubMenu);
                         function openSubMenu() {
                             $(this).find('ul').css('visibility', 'visible');
                         function closeSubMenu() {
                             $(this).find('ul').css('visibility', 'hidden');
    </script>
    <div id="TopMenu">
            <ul class="myMenu">
                <li><a href="#">Home</a></li>
                <li><a href="#">About Us</a></li>
                <li><a href="#">Products</a>
                        <ul>
                            <li><a href="#">Products1</a></li>
                            <li><a href="#">Products2</a></li>
                            <li><a href="#">Products3</a></li>
                        </ul>
                        </li>
                <li><a href="#">ContactUs</a></li>
            </ul>
        </div><!--TopMenu-->
    And in Umbraco I have created cshtml for it to work :
    <ul class="myMenu">
    <li><a href="/">Home</a> </li>
    @foreach (var page in @Model.AncestorOrSelf(1).Children)
        string style = "";
        if (1 == 1) { style = "class=\"current\""; }
        <li><a href="@page.Url" @style>@page.Name</a></li>
    The Above razor syntax works fine for AncestorOrSelf(1) which is Top level , but i need sub nodes for products which is AncestorOrSelf(2), Does any one knows how to acheive this
    Thanx
