Any one had this problem ?
In IE9 I'm not able to sort the macros, nothing happen when dragging.But if I change to IE8 in developer tools, it works like a charm.
I don't any JS errors ...
Must be the same issue as this one: http://umbraco.codeplex.com/workitem/30137
Go vote to make sure this gets included in 4.7.1.
I solved by using the latest jQueryUI build (1.8.14). Not sure if it will affect other things :()
No sorting in Macro Container and IE9
