  • Matt Stueve 30 posts 49 karma points
    Aug 03, 2011 @ 19:07
    Matt Stueve
    Segmented Administrator Users?
    Hi all,
    We have an Umbraco instance that stores a bit of content for multiple clients. Each client has its own start node in the content tree and we're easily able to segment users off to only manage their own sections of content.
    However, we would like to create an admin user for each of these clients that is able to create additional user accounts for their own area. So if I am super admin I can create an admin user for Client A and an admin user for Client B. When Client A Admin logs in, he can create additional users that are only able to see Client A's content and he does not have any visibility into Client B's users at all.
    Is this possible? I did some googling but couldn't find anything.
    Thanks!
    Matt
  • Richard Soeteman 4053 posts 12926 karma points MVP 2x
    Aug 04, 2011 @ 08:42
    Richard Soeteman
    Hi Matt,
    There is no easy way to solve this I guess. What you could do is hide any information for the other client using the event system. This requires that each member has some property that you can use to identify the company and in any other case maybe build a custom section, this will be a lot of work .
    Richard
    Aug 04, 2011 @ 19:04
    Matt Stueve
    Thanks for the reply, Richard.
    I assumed this was probably the case but wanted to throw the question out there in case others may have run into the same issue in the past. Thanks for the feedback and I'll keep those options in mind moving forward.
    thanks again,
    Matt
