They can assign a class of 'new', 'word', 'adobe' etc to items within the table using the styles dropdown in the TinyMCE editor. The problem is that a lot of the time the style gets applied to the table cell TD instead of the text inside the cell. This can then be difficult for the client to remove the style (the 'remove formatting' button doesn't work, and selecting another blank style in the 'styles' dropdown doesn't help either), and in the case of the last column it then causes the text to be too indented (eg. 5th row down, last column - how the word doc is indented). Is there a way to force P tags to be inserted with the classes instead of having the classes applied to the TD?
TinyMCE table cell style issue
I have a client who updates one of their pages with various types of documents - http://www.surfrescue.com.au/main/administration/circulars/
