Page content not updated when properties of an included media item is deleted
I'm working on a site where there is a carousel of images taken from a media folder.
Each of the media items have a number of sub nodes of related properties. These are used to add and position editable bits of content related to the image (like labels)
When I add or update a property sub node for a media item, the page where the images are included is updated when I refresh the page.
When I delete sub node of a media item and refresh the relevant page, the content isn't updated.
If I save&publish the page where the media items appears and re-load my page, it then displays properly.
Give that it works when adding and editing a sub node, but not when deleting, this looks like a bug in Umbraco refreshing the xml cache.
Has anyone done anything similar, or come across a similar issue?
This might be a bug in the umbraco media cache. Are you using library.GetMedia(id, true) in xslt? If you delete a subnode you probably also need to save the parent node to update the cache of that node.
The fact it updates without any further action when adding or editing a sub-node but not when deleting is what makes me think this is a bug.
Clicking to save the parent media node does update the content, so at least this is a better workaround than having to save and publish the actual content node.
I'm using Umbraco 4.7 with an xslt macro
Tom
Jeroen
It is using library(GetMedia(id,1)
Yes this is exactly what I just described and probably a bug. You should create a workitem for this on http://umbraco.codeplex.com/workitem/list/basic.
Jeroen
Workitem created at http://umbraco.codeplex.com/workitem/30406
Please vote it up
