apologies if this topic has already been brought up before. However I haven't been able to find anything that can help me with my problem.
Basically, I have created the following templates: Website Website Home Page Website First Level Website Second Level Each of the templates have the respective document types setup and linked correctly (as far as I am concerned) to their child nodes.
The content structure that I have setup is as follows: Content Home Contact Us Directions Map About Us Our History Major Clients
So far, so good, it all seems logical and simple. Also, this is my second Umbraco site and this setup worked perfectly in my first site. So.... here with the issue.
Essentially, it would seem that if I try and access the second level nav, nothing gets displayed. In terms of the difference in setup between the two projects, the only thing is, that on my first project I used a template to start off with. The second project, I started from the ground up. SO ran the install and did not install a template.
Any help will be appreciated as I have no clue. Thanks
First suggestion: try adding ?umbdebugshowtrace=true and find out how umbraco is trying to render that page. I know it'll tell it be using the 404handle, but maybe there's already a clue in the trace statements before that? Can you check?
You sir, are a legend. You have given me the ability to see something that I would never have figured. I didn't even think to use the debug method. I get this error:
template
Master template is the same as the current template. It would course an endless loop!
Now I must try and figure out what that means and how to fix it. :)
After further investigation. I see that my master template (ie Website) is set to have no master template. As in the drop down list is set to none. Also, if I navigate to a different third level document like http://dev.glmi.co.za/contact-us/directions.aspx, I still get a 404 thrown but in the debug mode (?umbdebugshowtrace=true) it no longer shows the same error as above. I now get this in the trace route:
Category Message From First(s) From Last(s) aspx.page Begin PreInit umbracoInit handling request 1.88201993435514E-05 0.000019 request handler current url '/contact-us/directions.aspx' 0.000108472785307378 0.000090 umbracoRequestHandler xpath: '/root/*/* [@urlName = "contact-us"]/* [@urlName = "directions"] | /root/* [@urlName = "directions"]' 0.000150903780191022 0.000042 umbracoRequestHandler Just before xPath query (False, '/root/*/* [@urlName = "contact-us"]/* [@urlName = "directions"] | /root/* [@urlName = "directions"]') 0.000179647357370264 0.000029 umbracoRequestHandler pageXPathQueryStart: '/root' 0.000192992589632055 0.000013 umbracoRequestHandler Adding to cache... ('/contact-us/directions.aspx') 0.000303860673037703 0.000111 umbracoRequestHandler After xPath query 0.000317548090742104 0.000014 umbracoRequestHandler Access checking started 0.000339790144511756 0.000022 umbracoRequestHandler Page not protected 0.000358268158412698 0.000018 umbracoRequestHandler Access checking ended 0.000369560278018828 0.000011 umbracoInit Done handling request 0.000379483655854519 0.000010 umbracoPage testing altTemplate 0.000510198494931549 0.000131 umbracoPage Element loaded: bodyText 0.000560841940437833 0.000051 umbracoPage Element loaded: hideInNav 0.000584452735977925 0.000024 umbracoPage Pagedata loaded for Directions (ID: 1083) 0.000598140153682326 0.000014 umbracoPage Looking up skin information 0.000623804061878078 0.000026
The part that really boggles my mind is the second last line. Pagedata loaded for Directions (ID: 1083). That is the exact correct PageId for the page that I am trying to call.
Issue with displaying second level documents
Hi All
Website
Website Home Page
Website First Level
Content
Home
Contact Us
Directions
Map
About Us
Our History
Major Clients
If I try and access http://dev.site.co.za/ (setup as such in IIS). All is good.
If I try and access http://dev.site.co.za/about-us.aspx or http://dev.site.co.za/about-us or http://dev.site.co.za/1067 . All is good.
HOWEVER
As soon as I try and access http://dev.site.co.za/about-us/our-history.aspx (or any varient thereof) Umbraco throws a 404 and displays me the general 404 page. This is confusing the hell out of me. An example of where this setup does work, can be found here at http://www.49million.co.za/get-involved/downloads.aspx.
Ricardo Carvalho
Ricardo,
/Dirk
Dirk
Thanks again for a quick reply.
Regards
Ricardo Carvalho
