  • Thomas Dolberg 74 posts 95 karma points
    Aug 15, 2011 @ 22:56
    Thomas Dolberg
    redirecting a node to a single url
    right now I can access a node with the following URLs (at least):
    - nodeName.aspx
    - nodeName
    - nodeName/
    how do I setup urlrewriting so all other requests for the node will permanently redirect to "nodeName/" ? I want to do it, because Google will see the above three URLs as three different pages and think it is duplicate content.
    thanks
    Thomas
  • Stefan Kip 1614 posts 4131 karma points c-trib
    Aug 15, 2011 @ 23:40
    Stefan Kip
    Hi Thomas,
    I've put together a regex for you to do this:
    ^([^/]+?)(?:\.aspx)?$
    This will match string like 'nodename.aspx' and 'nodename' (without an ending slash). They both capture 'nodename', so you'll have to redirect to '{R:1}/' which means '<group1>/'.
    Greets.
    Aug 20, 2011 @ 20:22
    Thomas Dolberg
    Hi kipusoep
    thanks for the regex.
    I ended up using the rewrite URLs at http://umbraco.miketaylor.eu/2010/11/03/url-rewriting-and-seo/ since they cover all the things I need.
    best regards
    Thomas
