Using umbraco 4.7 I have updated my tinymce.config to allow html 5 element article i then paste into tinyme html my html which has article tag. When i save i get [tidy error]
Anyone seen this before?
Regards
Ismail
in answer to my own question i just turned off tidy in tinymce not sure i need it, unless client pastes from word.
Where did you go to turn it off?
nm, found it:
http://our.umbraco.org/wiki/how-tos/customizing-the-wysiwyg-rich-text-editor-%28tinymce%29/allow-any-markup-in-the-tinymce-editor
I'm using v4.5.2 and unfortantely the steps to disable Tidy in the links above do not help in me get rid of the [Tidy Error] I'm experiencing in IE9. Neither does the solution mentioned in this post: http://our.umbraco.org/forum/ourumb-dev-forum/bugs/13785-IE9-[tidy-error]?p=1
Does anybody have any other suggestions about how to solve this issue?
Thanks a lot inadvance.
Kim
tidy error
Regards
Ismail
nm, found it:
nm, found it:
Kim
