  • Jacob Jensen 40 posts 60 karma points
    Aug 17, 2011 @ 17:16
    Jacob Jensen
    urlrewrite, regex help
    Hi.
    Iwe just upgraded a solution from 4.0 to 4.7, the old solution had a rewrite like this:
    <add name="ShopRewrite"
    virtualUrl="^~/(.*)"
    rewriteUrlParameter="ExcludeFromClientQueryString"
    destinationUrl="~/?alias=$1"
    ignoreCase="true" />
    The rewrite worked perfectly on the old version, because of the aspx extensions to normal pages, but iwe set
    <add key="umbracoUseDirectoryUrls" value="true" />
    And now the rewrite hits every page :/
    I need the rewrite to take only url without the last "/"
    Ex, i have a page called "frontpage", the url is:
    http://localhost/frontpage/ <- this one should not hit the rewrite
    Further i have 600 shops with an url alias as a property, the url generated is ex:
    http://localhost/spar-aarhus <-- this one should his the rewrite, because of the missing last "/"
    Please tell if u need any more information.
    Thx in advance.
    Jacob.
  • Stefan Kip 1614 posts 4131 karma points c-trib
    Aug 17, 2011 @ 17:28
    Aug 17, 2011 @ 17:31
    Jacob Jensen
    thx !!!
    Aug 17, 2011 @ 18:01
    Jacob Jensen
    hey, it seems like it removes the last char:
         virtualUrl="^~/(.+)(?:[^/])$"
         destinationUrl="~/?alttemplate=butik&amp;alias=$1"
    ex:
    http://localhost/store2 = http://localhost/?alttemplate=butik&store
    if i type
    http://localhost/store2x = http://localhost/?alttemplate=butik&store2
    Do u have a fix ?
    Best regards
    Jacob
    Aug 17, 2011 @ 18:08
    Stefan Kip
    Hmm yes I see, sorry about that.
    Let me take a look and I'll get right back at ya!
    Aug 17, 2011 @ 18:09
    Jacob Jensen
    np, glad for ur help :) !!
    Aug 17, 2011 @ 18:15
    Stefan Kip
    Sorry, I can't seem to find a 'nice' fix. There's a quickfix though:
    destinationUrl="/?alttemplate=butik&amp;alias=$1$2"
    Aug 17, 2011 @ 18:16
    Stefan Kip
    Oh wait, I made a mistake, this is the quickfix:
         virtualUrl="^~/(.+)([^/])$"
    Aug 17, 2011 @ 18:28
    Jacob Jensen
    pefect, it works perfectly !..
    thx
    Aug 18, 2011 @ 13:08
    Jacob Jensen
    Changed to:
             virtualUrl="^~/(/.+)([^/.])$"
    the other one hit /webresource.axd :)
    /J
