  • Narayana 1 post 21 karma points
    Aug 18, 2011 @ 06:40
    Narayana
    Huge number of entries - cmsPropertyData
    Hi All,
    I am using umbraco and the database being used is SQL Server 2008.Whenever I save and publish a content a new entry is added into the cmspropertydata.Due to this the database has lacs of records.It would really be great if you could guide by letting me know on how instead of adding a new record for every save and publish how an existing record can be updated for the same topic.
    I have a page that has a text box to submit text,so every time I edit and publish the text a new line is created in the database.THis further slows down the query time when used
    Thanks in Advance
    Aug 18, 2011 @ 09:07
    Dirk De Grave
    Narayana,
    this is by design, as you get versioning and rollback features for free. If, however, you want to clean up your db and remove redundant document versions, i'm sure you'll find some pointers if you search for it. I know there used to be packages which could deal with cleaning out the db, but not sure if there still available and whether they're fit for your umbraco version.
    /Dirk
  • Mike Chambers 636 posts 1253 karma points c-trib
    Aug 18, 2011 @ 10:07
