  • firepol 125 posts 173 karma points
    Aug 18, 2011 @ 17:11
    firepol
    Audit Trail: UmbracoExamine Field "InternalIndexSet" is listed multiple times (how to fix this?)
    in many of my umbraco website' tree nodes (which are of different document types), in the Audit Trails I see this kind of entry:
    "custom     admin     10 August 2011 16:54:53     [UmbracoExamine] Field "InternalIndexSet" is listed multiple times in the index set "updateDate". Please ensure all names are unique"
    Besides the date, the message is always the same, for different document types...
    So I wonder what does it mean? I don't understand (I'm quite new in umbraco) this but I'd like to fix this so that the logs will be cleaner... like this the Audit Trail is quite "dirty"...
    Thanks for helping & cheers
  • Dallas 133 posts 405 karma points
    Feb 19, 2013 @ 17:09
    Dallas
    Did you ever find an explanation for this?
    This has started occurring on a website of ours. The UmbracoLog table has many instances of this message, and it seems to have just started. It is not clear what change would have caused it to start it occurring. It also shows up in the Audit Trail as it has node associated with it in the UmbracoLog table.
    The site is running Umbraco 4.7.1.1.
    Dallas
    Feb 21, 2013 @ 09:03
    firepol
    Hi Dallas,
    unluckily nobody replied and I never investigated it further, as the logs are not a big priority in our business as you can imagine...
    I would suggest to ask in stackoverflow, maybe somebody will be motivated to investigate and answer in order to get some "reputation points"...
    in case you get news please share. Good luck and best regards
