  • Phillip Ng 148 posts 250 karma points
    Aug 25, 2011 @ 04:59
    Phillip Ng
    Restrict access to certain document properties
    Hello!
    I was wondering if I would be able to restrict access to select properties of a document. For example, if I had a simple editor and a rich text editor on the same page, could I give Person 1 access to just the simple editor and not the RTE? Thanks in advance for the help!
    Phil
  • Mike Chambers 636 posts 1253 karma points c-trib
    Aug 25, 2011 @ 08:50
    Mike Chambers
    you could place each property on a tab and use attackmonkey's tab hider to control which tab each person could see, you'd have to make each user a single member of a group.
    [http://our.umbraco.org/projects/backoffice-extensions/attackmonkey-tab-hider]
    Aug 25, 2011 @ 18:12
    Phillip Ng
    Thanks, that'll work. Appreciate the help!
