  • Vishal G.P 62 posts 122 karma points
    Aug 25, 2011 @ 11:19
    Vishal G.P
    mandatory field does not work for ucomponents dropdown checklist
    Hey guys,
    i have a ucomponents dropdown checklist which needs to be a mandatory field.. I checked the mandatory property when adding it to the properties of a doc type..
    But on the page i can leave it empty and it doesnt complain.. I was wondering if someone else has this problem as well..
    Can i alternatively add a regex to check for empty strings?? (my regex know-how is a bit rusty).
    Dropdown checklist adds the selected values, comma seperated..
    i hope someone can help out..
    Thanks in advance.
  • Vladimir Knobel 95 posts 171 karma points
    Mar 04, 2012 @ 20:33
    Vladimir Knobel
    Same problem here, any solution?
    Apr 22, 2012 @ 23:42
    Lee Kelleher
    Update on this issue, we've now implemented the mandatory check for the DropDown CheckList data-type. (More info on our CodePlex)
    The fix will be available in the next bug-fix release, v3.0.4 ... no firm dates yet, (next week or so), but do let us know if you need it urgently.
    Cheers, Lee.
