  • Stephen 204 posts 246 karma points
    Aug 28, 2011 @ 20:56
    Stephen
    Display random page/text
    My Clients want the ability to enter a weekly tips, simple text and a date.  I need to be able to display a randomly selected weekly tip on the homepage, preferably in scrolling text left to right and have a tips page will display all of them. So i have two questions
    1.  Am i best having a Tips and TipItem doc type that are not accessible via the main nav that i can tap into
    2.  Are there any projects will pull in a random page and display in a scoller?
    Stephen
    Aug 28, 2011 @ 21:19
    Rich Green
    Hey Stephen,
    I usually have a separate 'Settings' section outside of the site for situations like this, something like:
    -- Content
    ---- Home
    -------- About Us
    -------- Contact Us
    -------- etc.
    ---- Settings
    --------Tips
    ---------- Tip 1
    ---------- Tip 2
    As for pulling out the random nodes you can use the xslt from here http://stackoverflow.com/questions/1389127/randomly-choose-a-node-in-xslt
    Cheers
    Rich
    Aug 28, 2011 @ 23:14
    Stephen
    Hey Rich thanks for the feedback...
    Is there a reason to set this up outside the main content? I'm new to umbraco and often wondered where I should put things that are not necessarily HTML content but take care of things like lists for drop down selections in a form, would this be applicable to that?
    Stephen
    Aug 29, 2011 @ 00:30
    Rich Green
    Hey Stephen,
    I always have a settings section, however in this case possibly I would have it like this:
    --Content
    ----Home
    ------ Tips
    -------- Tip 1
    -------- Tip 2
    It's just a matter of preference or  whatever is easier for the content editor to edit in this case.
    It's up for discussion when content is not content (as in this case the Tip will not be rendered on it's own, only in the context of the homepage).
    As for dropdowns in a form, yes I always put these in settings over the drop down datatypes as the user can edit them.
    There's no 'right' way but I'd most sites I've seen other developers set up have a settings section of some type.
    Cheers
    Rich
    Aug 29, 2011 @ 13:56
    Stephen
    thanks Rich, i think i'm going to include a image and a tip, would the structure still apply?
    Aug 29, 2011 @ 15:06
    Stephen
    Hey Rich, using that code below but i'm getting no output? Am i doing this right?
    <!DOCTYPE xsl:Stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
    version="1.0"
    xmlns:Exslt.ExsltMath="urn:Exslt.ExsltMath"
    exclude-result-prefixes="msxml umbraco.library Exslt.ExsltMath">
    <!-- This should probably be a macro parameter so you can use this elsewhere-->
    <xsl:variable name="parentNode" select="1381"/>
    <xsl:template match="/">
            <xsl:variable name="numberOfNodes" select="count(umbraco.library:GetXmlNodeById($parentNode)/node)"/>
            <xsl:variable name="randomPosition" select="floor(Exslt.ExsltMath:random() * $numberOfNodes) + 1"/>
            <xsl:variable name="randomNode" select="umbraco.library:GetXmlNodeById($parentNode)/node [position() = $randomPosition]"/>
              You now have the node in the $randomNode variable
              If you just want the id then you can do an XPath query on the variable
              or you can modify the XPath above to get the property you are after rather than
              the whole node
      <xsl:value-of select="$randomNode/tmQuote" />
      <img src="{$randomNode/@nodeName/hpImage}" alt="" title="" class="hpImage" />
    </xsl:template>
    </xsl:stylesheet>
  • Bjarne Fyrstenborg 1286 posts 4060 karma points MVP 9x c-trib
    Aug 29, 2011 @ 16:05
    Bjarne Fyrstenborg
    Hi Stephen
    I have done something similar to display a random quote, where a had Quotes and Quote doctypes... and the Quote doctype could have the properties I needed: http://our.umbraco.org/forum/developers/xslt/20274-How-to-display-random-quote
    Furthermore there is this wiki http://our.umbraco.org/wiki/how-tos/xslt-useful-tips-and-snippets/xslt-getting-a-random-document-when-the-page-reloads where it uses root instead of a specific doctype in the first link..
    Bjarne
    Aug 29, 2011 @ 16:06
    Dennis Aaen
    Hi Stephen,
    The reason I think you get no output when using the code you have posted is that this uses the old XML schema. And I assume that you are using a newer version. Probably 4.7 right?
    If so, try something like this and see if you have better luck.
    <xsl:stylesheet
    version="1.0"
    <xsl:variable name="numberOfNodes" select="count(umbraco.library:GetXmlNodeById($parentNode)/* [@isDoc])"/>
    <xsl:variable name="randomNode" select="umbraco.library:GetXmlNodeById($parentNode)/* [@isDoc][position() = $randomPosition]"/>
    the whole node
    </xsl:template>
    </xsl:stylesheet>
    A useful tool when you, as you find something xslt based on the old form can be Tommy Poulsen's online xslt convert tool. You find the link here.
    http://blackpoint.dk/umbraco-workbench/tools/convert-xml-schema-to-45-.aspx.
    The way you can see the xslt code uses the old form can often be in such <xsl:variable name="numberOfNodes" select="count(umbraco.library:GetXmlNodeById($parentNode)/node)"/>. Node does not exist in the new schedule, this has been replaced by a [@ isDoc].
    I hope it can help you on the right track
    /Dennis
    Aug 29, 2011 @ 16:44
    Stephen
    Hey Dennis,
    Thanks for the post and link the convert tool.  Still not working with the new code...does not seem to be getting the random node..i found another XSLT that can get a random from a media folder that works well...would still like to work out how to do it on a folder though
