    Aug 29, 2011 @ 10:02
    Anthony Candaele
    Examine does not index content
    Hi, I have a problem with Examine, it doesn't index anything. If I look in an index file, the only thing that's there is:
    "ÿÿÿ÷  9µ;J                o&TB"
    I have configured my IndexSet like this:
    <!-- Custom index set for searching the menarg website -->
        <IndexSet SetName="MenargIndexSet" IndexPath="~/App_Data/TEMP/ExamineIndexes/MenargWebsite/">
            <IndexAttributeFields>
                <add Name="id" />
                <add Name="nodeName"/>
                <add Name="nodeTypeAlias" />
                <add Name="parentID" />
            </IndexAttributeFields>
            <IndexUserFields>
                <add Name="bodyText" />
                <add Name="umbracoNaviHide" />
            </IndexUserFields>
            <IncludeNodeTypes/>
            <ExcludeNodeTypes />
        </IndexSet>
    Is there something wrong with this configuration?
    Thanks for your help,
    Anthony
    Aug 29, 2011 @ 10:12
    Rich Green
    Hey,
    Did you remember to add the provider into /config/ExamineSettings.config as well?
    Rich
    Aug 29, 2011 @ 10:35
    Anthony Candaele
    Hi Rich,
    Yes, I added it:
    <add name="MenargSearcher" type="UmbracoExamine.UmbracoExamineSearcher, UmbracoExamine"
                 analyzer="Lucene.Net.Analysis.Standard.StandardAnalyzer, Lucene.Net" indexSet="MenargIndexSet" enableLeadingWildcards="true" />
    Aug 29, 2011 @ 10:41
    Rich Green
    Hmm, anything relevant in the umbraco log table?
    Rich
    Aug 29, 2011 @ 10:45
    Dirk De Grave
    And your indexer? Did you add that one as well?
    /Dirk
    Aug 29, 2011 @ 10:47
    Anthony Candaele
    Hi Dirk,
    Yes, I added the indexer as well:
    <add name="MenargIndexer" type="UmbracoExamine.UmbracoMemberIndexer, UmbracoExamine"
                 supportUnpublished="false"
                 supportProtected="true"
                 interval="10"
                 analyzer="Lucene.Net.Analysis.Standard.StandardAnalyzer, Lucene.Net" />
    Aug 29, 2011 @ 10:51
    Anthony Candaele
    @Rich, no I don't find anything relevant in the umbracoLog table
    Aug 29, 2011 @ 10:52
    Rich Green
    Even when you publish your nodes?
    Also did you restart the site after you made the config changes?
    Rich
    Aug 29, 2011 @ 11:03
    Anthony Candaele
    @Rich I restarted the webserver. No change. If I look in the ExamineIndexes/MenargWebsite/Index folder the two files in there, segments.gen and segments_1, have a datestamp of 26/08/2011
    However I look in the ExamineIndexes/MenargWebsite folder, there are two files there, PS54C002.exa and PS54C002.lck that have a datestamp of today (29/08/2011)
    Aug 29, 2011 @ 14:01
    Anthony Candaele
    phew, found it, I mistakenly copied the InternalMemberIndexer node:
    <add name="InternalMemberIndexer" type="UmbracoExamine.UmbracoMemberIndexer, UmbracoExamine"
               supportUnpublished="true"
               interval="10"
               analyzer="Lucene.Net.Analysis.Standard.StandardAnalyzer, Lucene.Net"/>
    But this node has some different settings than the normal content indexers, more specifically the 'type' and 'analyzer' settings are different.
    I changed the value for the 'type' setting to: type="UmbracoExamine.UmbracoContentIndexer, UmbracoExamine"
    and the value for the 'analyzer' setting to: analyzer="Lucene.Net.Analysis.WhitespaceAnalyzer, Lucene.Net"
    and now it works :)
