Can't you use the standard asp.net login controls which have options to control whether authentication cookies is persisted... On the other hand, there's still an issue with using membership logout functionality in umbraco (should be addressed in v4.7.1), seems that user is still logged in, even though you'd login as a different user.
nForum's code has a fix for that... (Check the LogoutMember function), you'd need to use that one to make sure members get logged out correctly
The reason for not using the standard .net controls is, that I need complete control over the markup - and as far as I know, that cannot be accomplished with the standard .net login control. And to my understanding the standard .net controls pipe the login call through to the FormsAuthentication anyway - correct me if I'm wrong :-)
I've already implemented the fix for logging out users correctly - my only concern at the moment is the fact that login state is persisted between sessions - even though I should've handled that by calling the method with the "false" param.
Member login persisting between sessions
Hi all,
I've just created a member area on a new solution running 4.7.0.
I've created a UserControl for validating and logging in members. The following code is used for the validation process:
In my understanding the "false" part in the code should mean that member state isn't persisted between sessions.Have anyone experienced anything similar, or have any thoughts on how to solve the problem?
Many thanks in advance
Martin,
/Dirk
Hi Dirk,
Thanks for your comments.
