  • julius 107 posts 289 karma points
    Sep 02, 2011 @ 23:15
    julius
    All my article pages result in a 404 / not found
    I have Category and Article Page document types. All Category nodes in my content tree display fine, but all Article Page nodes result in a 404.
    I have republished the tree, and I have looked in the XML cache. I can see the article pages are present in the cache, but they are somehow not found..
    Page not found
    No umbraco document matches the url 'http://local.mydomain.com:8080/cursussen/microsoft-office/access/this-is-a-test.aspx'
    umbraco tried this to match it using this xpath query'/root/*/* [@urlName = "cursussen"]/* [@urlName = "microsoft-office"]/* [@urlName = "access"]/* [@urlName = "this-is-a-test"]')
    The url names in the query are present in the cache and the nesting is correct, but still I only get a 404.  Could the two /* /* things at the start of the query be wrong?
    Sep 03, 2011 @ 10:32
    julius
    I think I fixed this. The problem was that my article pages had no template assigned to them. After creating a template, assigning it to one of my articles and republishing it, that article works.
    I was confused by the Umbraco 404 message, because it seems to suggest the node doesn't exist.
    Anyway, problem solved :-)
