  • Stephen 204 posts 246 karma points
    Sep 04, 2011 @ 10:53
    Stephen
    Store info with my form control
    I've developed a specific form for a cllient and imported into Umbraco as a control and all is working well however if i was doing this in a .Net site i would be doing 2 things.
    1. Capture data in the email and send to client.(i'm doing this for the umbraco control)
    2. Capture data to database and allow the cllient view the form enquiry details via the cms.(not doing this)
    as this is only my 2nd umbraco website I'm not sure how this should be done...can i just continue as normal and capture the data to umbraco database i'm using? I've seen some extra tabs on the umbraco install for other starter kit forms, is this done in the same way?
    Regards,
    Stephen
    Sep 04, 2011 @ 11:00
    Rich Green
    Hey Stephen,
    You have a few options.
    1) Add then as nodes in Umbraco using the API (easy to do), means your client can view/edit them in the admin system.
    For this usually use a structure like this
    -Content
    ----Home
    ------About Us Etc
    ----Settings
    ------Form Responses
    -------- Response 1
    -------- Response 2
    -------- Response 3
    2) Alternatively you can add them to a SQL Server table (either using the Umbraco datalayer or any you prefer) and then add a custom section for viewing the responses
    http://umbraco.com/help-and-support/video-tutorials/developing-with-umbraco/custom-sections,trees-and-pages/adding-a-new-section.aspx
    Rich
    Sep 04, 2011 @ 14:07
    Stephen
    Hey Rich, option 1 sounds cool and the API is something I've yet to tap into...do you know of any good example on the site?
    Thanks for the reply.
    Stephen
    Sep 04, 2011 @ 14:12
    Rich Green
    Hey Stephen,
    The API is pretty simple once you get your Visual Studio solution set up and reference the correct dll's, here's the wiki http://our.umbraco.org/wiki/reference/api-cheatsheet
    Have you considered Contour, sounds like exactly what you need if you want to save some time, this saves results back to Umbraco and also allows your users to edit the form.
    Rich
    Sep 06, 2011 @ 10:47
    Stephen
    Yeah contour sounds like it ticks all the boxes but I have already quoted the client and the price did not include contour however they have moved the goalposts slightly with the number of forms they now want.  I do enjoy developing my own .net forms and think it would be a worthwhile exercise delving into the API to help with my learning curve though...
    Stephen
    Sep 06, 2011 @ 10:59
    Stephen
    So thinking this through with option 1, the simplified process could be as follows
    1. create a document type that contains all my form elements.
    2. using the api create a new document, in the settings folder, based on the form doc type.
    3. populate the newly created content with stuff from form.
    Stephen
    Sep 06, 2011 @ 11:06
    Rich Green
    Hey Stephen,
    Looks good, this is how we've done it on various projects, we use the doc types to create a 'form builder' which the client can create forms from themsealves, they can then drop them into any page they like.
    Regards
    Rich
    Sep 06, 2011 @ 11:21
    Stephen
    I dont think mine needs to be as complicated, the form is not going to change and the client does not need access to it, just need to store the response's somewhere and let the client see it. Been reading up on the API cheat sheet are there any example projects or code out there?
    Stephen
    Sep 06, 2011 @ 11:25
    Rich Green
    Hey,
    Not sure how up to date this is but sample application from Umbraco TV here http://video.umbraco.org/developer/events/samples.zip
    API / Events videos here http://umbraco.com/help-and-support/video-tutorials/developing-with-umbraco/events.aspx
    Rich
